Regelbare tractiecontrole
Dim
Auto: Exige S 240
Bericht door Dim »
Heeft er iemand ervaring met de Racelogic tractiecontrole ?
Lijkt een interessant iets, en is regelbaar...En zou te installeren zijn op de Elises/Exiges.
Niet enkel tractiecontrole, maar ook launchcontrol en datalogging...
Confer hieronder :
"The Standard TC system has six degrees of operation. (degree of oversteer in RWD application and degree of understeer in a FWD application). The Six levels are 0% wheel slippage (Wet conditions), 5% (Dry), 10%, 15%, 20% and off.
Setting a RWD vehicle to 5% in the dry will deter the rear end losing traction and a tail slide occurring. 5% in a FWD car will deter excessive understeer.
If the weather conditions deteriorate whilst the car is in use the system can be adjusted whilst in motion down to the wet setting and 0% wheel slippage, making the car much safer to drive in adverse conditions."
